Montero remote alarm
Old Mar 26, 2023 | 09:44 PM
Aal4403's Avatar
Default Montero remote alarm
Please help my montero 2014 glx manual remote controL doesn’t sound when lock and unlock button is pressed , what will be the problem please help thanks
Old Apr 10, 2023 | 08:47 AM
jrmdir's Avatar
Would help to know if it ever worked before. Did it?
Not sure about your exact model, but the alarm horn is usually separate from the main horns and has it's own relay and fuse. Check the diagram in the lid of the main fuse panel and/or your owner's manual and try swapping out any fuse or relay marked with a horn icon. You can exchange a fuse with a spare, and swap a relay with another one that you know works. E.g. the Fog Lamp relay?
If the fuses and relays are all good, then it's possible? there is an ECU programming flag that can be set to silence the alarm horn, but I don't know this for sure. If there is, it would require a programming tool that dealers have.
Good luck.
Aal4403
Mar 26, 2023 09:30 PM
alsaaron
Aug 19, 2014 11:23 PM
trucker5240
Sep 30, 2009 05:08 PM
avernet
May 6, 2009 02:24 AM
txboi4life86
Oct 16, 2004 06:37 PM
