Montero Sport V6 oil smoke profuse!!!???
2000 Montero Sport V6 with 120K miles smokinga lot while idling and profusely when giving throttle to clear out. Seems to clear up with no visible smoke running down the road at 60mph. This vehicle runs perfect, is immaculate inside, outside and underneath so appears it was serviced and cared for.
I made deal to purchase and went to pick up and saw all the oil smoke. Seller says this is common to Mitsubishi's while idling for several minutes. This is my first exposure to any Mitsubishi, so I would like to know of any known common issues with engine mechanicals. Buying for my 15 year old daughter and we both love the looks of the Montero Sport.
I had an old blazer that had a blown head gasket. Upon starting it would blow all kinds of smoke for a few minutes until it was warmed up, then it stoped for the most part. It was on its last legs, so I never fixed it. I don't know if this is the same type of thing as yours, but maybe something else to look into?
mxmikie, good information. It was so bad I thought it might be rings. I can't remember the last time I saw a vehicle this new smoke that bad. I have talked with several car dealers and Mitsubishi owners and the majority say that Mitsubishi's have this common smoking problem while idling. I just haven't found much on this forum. I'm not sure when the timing belt was last changed. Would you recommend changing the belt and tensioner while we're replacing the vvs? What is the rule of thumb for replacement of the timing belt, tensioner? Mileage?, Any other obvious predictive maintenance clues as to timing belt/tensioner due?Jeff
i bought my 95 montero SR cause it quit running (bad belt adjuster)160,000 miles i change all timing components and water pump started the truck (sat 2 years) after it warmed up smoked like a fog machine i bought/made the valve spring tool and changed the valve stem seals plugs and wires smoking stopped as did the burnt oil smell replaced the fuel pump and filter and a front axle seal haven had to open the hood since truck now has 230,000 miles
my 93 3.0 v6 was doing the same thing, ichanged the valve cover gaskets and the smoking stopped. it is a very easy fix, also it improved my gas milage for some reason. it is a relatively easy fix.
oil smoke during extended idling or upon initial startup is from worn valve seals and/or guides.
altough common on earlier model mitsus, the sports do not usually suffer this issue unless badly neglected. I suspect someone didnt bother changing thier oil.
the bandaid fix is new valve seals. the proper fix will probably be a valve job, as valve guide wear is undoubtedly present.
