New owner of Montero Limited 2003 need advice!
Hi,
new owner of 2003 Montero Limited V6 engine. All the best!
Please advise what oils & quantity you guys use for:
1. Transmission (was told 10l SP3 by the dealer and silicone as gasket
2. Differential;
2. Engine.
I will be changing the belt & water pump very soon too.
Last: My cruise dash lamp is always on & also the right wheel on the rear differential (this will disappear after 50-100km highway only...), any opinion?
THANK YOU!!!
);2. Differential;
2. Engine.
THANK YOU!!!
Congratulations on your purchase and welcome to the forum.
As far as fluids go, I'd recommend using ONLY Mitsubishi transmission fluid. Others may work for some time, but they all end up messing things up and causing transmission issues.
For differential you need 80-90 oil for Limited Slip differentials. I assume the 2003 has LSD. I've used both Mitsubishi and non Mitsubishi oils for this and both worked, as long as they are specifically for LSD type differentials.
For engine oil I always use 5-30 oil as per recommendations in the FSM.
The light indicators for rear wheels should always stay on. If they are not, you probably have a burnt out bulb and if one of the lights is going ON/OFF - possibly a bulb loose in the socket.
Regarding the cruise light - you have to push the button on the end of it in to toggle it off and on - it will stay on if you've never pushed the button in. It does not reset when the key is off. I had a 2003 now I have a 2006. Love my Monty.
With regards to Transmission fluid, I recently went to the dealer for a fluid change and they used Valvoline Maxlife Transmission fluid vs the Mitsu stuff. After a little research online it seems that it is an acceptable trade per the Valvoline website.
That is the first time I've heard of a Mitsubishi dealer who would use non-Mitsu fluid for transmission fluid change. I've always used Mitsubishi transmission fluid on my Montero and never had an issue. If you search this and many other Mitsubishi forums, you'll see that many transmission issues are related to using "compatible" fluids. Not saying that this is the true in your case. If I have a choice - I'd stick with what works for sure.
Good to know. Thanks for sharing.
I've got a 2006 Montero Limited with about 93k on it. Owned since new - no issues encountered. Is the transmission issue "usual" for the Montero's @ 100k? I've kept up with all service intervals at the local Mitsu dealership.
Actually - I do have minor issue - the fog lights stopped working - I think it's the switch as I no longer hear a click when I press it.
