no more smoke
Old Dec 16, 2006 | 11:45 PM
mxmikie's Avatar
Default no more smoke
i just did the vss on my 95 SR ......stopped all the smoke screen what a diff and no more burnt oil stink .............................VERY COOL
Old Dec 20, 2006 | 01:22 AM
lwolfnmonty's Avatar
Default RE: no more smoke
may I ask what a VSS is? I'm kind of an ameteur with the lingo, but my 94 SR is doing the same thing...(oil smell, smoke)
thanks.
Old Dec 20, 2006 | 03:11 AM
off roader's Avatar
VSS=Valve Stem Seal's. You can replace just the seals or do a full valve job depending on the age and resultant wear of your vehicle.
Can be done w/out removing the heads buy using the rope trick or LP air trick.
Old Dec 20, 2006 | 11:20 PM
Rumplecat's Avatar
Mxmikie:
How much did you spend on doing this if i may ask? Did you do it yourself or did you let the dealer do it? I am just curious.
Old Dec 22, 2006 | 09:15 AM
mxmikie's Avatar
i did it myself i bought one of those tools for overhead motors but their spring compressing tool sucked so i made one to work with the tool and it went real smooth i had the seals and a head gasket set when i removed the intake the center gasket had been replaced before but they missed the 2 rear ports and the butterfly shaft had a massive vacuum leak on the front of the manifold so i made a insert out of polyurethane and fixed the vacuum leak the truck would smoke when i came to a stop and when leaving a stop it smoked so bad i thought it was rings it has 190,000 miles on it but i did a compression test and all 6 holes were 8lbs within each other and after reading on the 3000gt boards mitsubishi has weak valve seals so after changing all 24 the smoke and burnt oil smell is gone.......... so if anybody wants to rent the tool $80.00 deposit and $25.00 rental mxmikie@yahoo.com
Old Dec 22, 2006 | 03:02 PM
mxmikie's Avatar
ORIGINAL: Rumplecat
Mxmikie:
i bought a head gasket set on ebay for $40.00 and changed them in a weekend i used compressed air the tool i bought has all the fittings the tough part is getting the old seals off the valve guide there is very little room to grab them
car doctor
Aug 9, 2015 04:52 PM
BrunoBoy650
May 31, 2006 07:39 PM
jap901
Jul 24, 2005 10:05 PM
GPR1
Mar 14, 2004 10:31 PM
