only center brake light works
Last night wife tells me her brake lights are not working. Checked it out and the left and right brake lights are not working but the third brake light does...
2002 Montero Sport 3.0 AWD Question. Does the third brake light work on a separate circuit? Question. Since the brake lights do not function as a turn signal, does the wiring run thru the turn signal in the steering column harnesses? Question. Has anyone had this problem and what was the fix. |
Simple things fist - check fuses and bulbs.
