-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   Passenger Cam jump (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/passenger-cam-jump-57489/)
GIVOLS Aug 29, 2024 10:37 AM
Passenger Cam jump
2002 Montero sport 3.5 changing timing belt and when I took off tensioner cam on passenger side jumped quarter of a turn forward.
can I move it back counterclockwise or move it forward or do I need to back crank a few teeth before I move move it
b
HunterD Aug 30, 2024 04:13 PM
Yes, you can move it back into the right position. Go the closest distance. If you get interference, stop and try to move the crankshaft, then move again. It might be tricky, but doable. Been there, done that...
GIVOLS Aug 30, 2024 06:03 PM
Thanks Man
that worked !!!. Had to move crank a few teeth
Barry
