Passenger side Low beam not working on 2001 Montero Sport
Old Feb 8, 2019 | 12:20 PM
WillGlazier's Avatar
Default Passenger side Low beam not working on 2001 Montero Sport
Hello all,
The passenger side low beam stopped working, so my first thought was to change the bulb. After changing it out, the problem remains. High beam works fine, but no low beam. The driver's side works fine on high or low. Ive checked the connections and visually checked the connector and wiring that i can see. Any ideas?
Old Feb 13, 2019 | 02:50 PM
I believe there are separate fuses for Right and Left side head lights. Check the fuse box fist. If fuses are OK, check if you are getting voltage at the low beam connector on passenger side? Then you can proceed to further troubleshooting.
taybrynn2
Mar 9, 2018 01:57 PM
Vadimus
Dec 17, 2012 06:04 PM
lawtownzballer
Mar 25, 2011 04:22 AM
bishigt_18
Nov 1, 2008 07:24 PM
weigojmi
Jan 28, 2008 09:14 AM
