-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   Piston Position for TDC (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/piston-position-tdc-57324/)
Serviceman May 12, 2024 02:03 AM
Hi Guys
I have a 2006 NP pajero with a 3.8L engine
Timing belt snapped off
Taken the heads off for a rebuild ( suspect belt valves? )
With the heads of, I rotate the engine to align the crank timing, yet piston 1 is down
2 and 5 are up.
Just need confirmation this is correct
Keep in mind the belt snapped so I'm starting from scratch......
https://cimg2.ibsrv.net/gimg/mitsubi...b73a435054.jpg
https://cimg3.ibsrv.net/gimg/mitsubi...f1fbbb7d5f.jpg
HunterD May 14, 2024 01:00 AM
That is not the timing mark. If you remove the crankshaft pulley, you'll see the dot imprinted on the front of one of the teeth. That is the proper mark
https://cimg0.ibsrv.net/gimg/mitsubi...ede131196a.jpg
Serviceman May 14, 2024 01:20 AM
Thanks for the reply.
glad u pointed this out. Appreciate the reply.
