Rear crankshaft seal replacement 2001 Montero XLS
Can anyone give some insight in replacing rear main seal?
You have to pull the engine to go that. No other way to get to it. I think you can get to it by removing transmission. However, removing and installing rear main seal carrier is difficult without removing the oil pan.
Originally Posted by HunterD
(Post 338632)
Whichever way you're going to go about, it's a lot of work. You're going to work with heavy hunks of metal. Do not hurry and make sure you're doing it safely. Best of luck.
| All times are GMT -5. The time now is 03:36 AM. |
