Removing Intake Plenum - '00 Montero
Yes, there are lots of repair threads, but I don't see many on the 2000 model year, full-size Montero.
So here is a little info on removing the intake plenum, which is the first step of a number of repair jobs including:
1. Replacing spark plugs and wires
2. Replace valve cover gasket
3. Replace o-rings on rear cam seals
4. Replace lifters
5. Anything requiring access to the cylinder head
Note, you do not need to remove the plenum to change the timing belt, luckily.
4. Replace lifters
Trying to post pictures for this thread!
My idea for this thread was to get it started with a short intro, and then use replies to post pictures with mark-ups and comments.
So I've tried to post the first reply with pictures, but it's not been approved yet.
I hope it will work out so this thread serves a useful purpose.
I just wanted everyone to know what I'm trying to do here, being as my original post doesn't make much sense by itself.
Maybe linking to my album...
cjolsen.....OK, I went to the link with the 5 pictures, and they are helpful. I guess that is a downfall with some of these Mitsubishi's.......to have to do all this work just to get access to the spark plugs. Something I will have to learn how to do with my 94 Montero SR with the 24valve engine.
Nice job with the pics. I have the same plenum on my 2001 full size Montero and I can confirm that you got all the bolts marked. I have to say - I always remove mine in two step process (upper half, them lower half). Because of that it, there are few more bolts involved and two nits by ERG passage. I find it easier to maneuver two pieces instead of one big assembly. Perhaps it has something to do with how the engine compartment configured? Anyhow, I'm sure this will be useful to many users.
Same process for the 97~04 montero sports. I made a contraption/blueprint out of cardboard where I shove the bolts through the respective holes to keep them in the right spots for reassembly. Gonna try color coding them next maybe, god I've taken off my plenum too many times over the years.
Naeos......I like the cardboard idea for keeping the bolts arranged as Ive done that in the past. The paint trick seems good too. Im sure Hunter is working on designing and fabricating a new plenum that fits elsewhere on the engine so the spark plugs can be changed without removing it.......and he will be sending us each one for our rigs very soon. Ha ha.
Naeos......Thats way cool, and a huge task........but I can picture it now......cutting a 2' x 2' hole in the hood and mounting that bad boy up above the hood for all the world to admire. Add a row of orange butterfly flappers, and you just might have to attach a parachute on the rear to make people really wonder. And you can change the plugs every weekend if you want in a matter of minutes. I think I will buy one from you.
