Removing valve cover gaskets 00 Montero Sport
Old Jan 1, 2015 | 06:32 AM
tfeni52355's Avatar
Default Removing valve cover gaskets 00 Montero Sport
I changed the valve cover gaskets on our 00 Montero Sport the other day. Like many they were hardened and difficult to break loose. Once I got them off the engine I used a heat gun to soften up the gasket material and an awl to dig it out. The heat gun was a life saver. It took about 10 minutes to clean out the old gasket material per side.
Harbor freight seĺls a heat gun that works great for this. Money well spent.
Hope this helps!
Old Jan 1, 2015 | 02:31 PM
Good advice. I have not though of using a heat gun to soften the old material. That would have helped when i had to do it
Old Jan 2, 2015 | 11:02 AM
rich209's Avatar
good advice thanks ��.
Old Jan 2, 2015 | 05:23 PM
2001Mitch3.5XS's Avatar
Awesome thought, I will have to keep that in mind...Tks for the input.
Old Jan 12, 2015 | 01:55 PM
Anferney's Avatar
I need to do the valve cover gasket job too for my 2001 Montero Sport. I can't find a procedure to do it though. I bought a manual from ebay, but it doesn't include a VCG removal/replace procedure. Under the hood, it looks like the intake needs to come out among other things. What procedure did you use?
Old Jan 13, 2015 | 04:53 AM
tfeni52355's Avatar
Go to Montero sport online forum and check the diy section.
Old Jan 13, 2015 | 10:16 AM
If your going that far into the motor with all that taken apart you mayaswell change the spark plugs, Change the spark plug/rubber gaskets in the valve cover. They are hard as a rock but will come right off with a tap of a hammer.
Old Jan 16, 2015 | 08:15 AM
Anferney's Avatar
Went to --> Montero Sport Online » DIY and didn't see a procedure for the VCG. Am I in the right place
Old Jan 16, 2015 | 08:16 AM
Anferney's Avatar
Good advice about the plugs, do you know which ones are correct or OEM? Advance Auto parts lists 39 plugs that are "exact fit". Also, will I need to change the intake plenum gasket too since it's coming off?
Old Jan 19, 2015 | 06:18 PM
yes the bosch iridium plugs n yes change the plenum gasket also Anferney.
