Replacing CHECK ENGINE Light Bulb??
Old Jul 23, 2012 | 12:44 PM
KIRK!'s Avatar
Default Replacing CHECK ENGINE Light Bulb??
I have a manual on the way, but I'm impatient. How much of a nightmare is it to replace the Check Engine light's bulb on a '99 (non-Sport)? I need to replace it to pass smog.
Thanks!
Old Jul 23, 2012 | 07:31 PM
Mr. Z.'s Avatar
When you remove the instrument panel the screws are the easy part.
Knowing the location of the plastic "clips" (FSM has locations for each and every one), makes the job much smoother. Other than that, it's fairly straight forward.
Here is a link you could use to order bulbs:
www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs
Old Jul 23, 2012 | 09:53 PM
KIRK!'s Avatar
Thanks!
klas
May 14, 2023 09:02 PM
guyjg
Nov 13, 2021 03:27 PM
pgb205
Jun 4, 2009 10:40 PM
c577
Oct 16, 2007 12:03 AM
misledyouth
Aug 24, 2005 02:49 PM
