Seattle Montero Mechanic?
Old Dec 6, 2019 | 07:54 PM
digger26's Avatar
Default Seattle Montero Mechanic?
Hi, i have an 01 Limited that needs some work. Does anyone know a mechanic in Seattle that is familiar with this vehicle? Thanks!
Old Dec 7, 2019 | 04:52 PM
Dentar's Avatar
Hi, Digger. I think this is my first post on this forum but hopefully this will help. I have a 2001 Limited as well that I bought about a year and a half ago. The previous owner provided most of the receipts for the work he had done. Will include a few of them here.
Earl's Garage - timing belt, water pump, etc.
-I actually went back to these guys a few months ago because the timing belt tensioner failed (previous owner had the above work done in February of 2018). They replaced it (out of warranty and it doesn't transfer anyway) and it's been fine since then.
Aurora Clutch and More - brakes and calipers
Harris Mitsubishi - power steering pump
Thanks.
Old Dec 7, 2019 | 09:47 PM
digger26's Avatar
Thank you! I have a issue with a weird sound after i depress the brake pedal. Also, i can't get it into 4x4. I dropped it off at a good reliable mechanic and he's having trouble diagnosing both issues. I'd like to find someone who has experience. I brought it to Pierre Mitsu on LCW and they were worthless. I may have to bring it up to Harris. Thanks
Old Apr 25, 2021 | 09:36 AM
whitley22's Avatar
Default Brake issue?
Any luck figuring out the brake issue? Any luck finding a local mechanic in the Seattle Area?
Old Apr 26, 2021 | 02:02 PM
digger26's Avatar
Hi, it was the brake accumulator. I have not found a good Montero mechanic in Seattle. It has been very difficult to find parts when it has needed maintenance. Lucky nothing major has failed.
If anyone else wants to chime in on a Seattle mechanic that'd be appreciated. Thanks!
Old Nov 22, 2022 | 05:33 PM
aspirin's Avatar
Younker Mitsubishi in Renton has been fantastic. I had a check engine light in my '02 Montero Sport that my usual mechanic couldn't figure out how to fix and he told me he thought it waas a bad ECM and I'd need a new one. Younker quickly, and cheaply, figured out it was a mis-routed vacuum line (I believe caused by my usual mechanic). Subsequently my harmonic balance failed. My neighbor and I couldn't get the crankshaft bolt out, my usual mechanic also tried and couldn't budge it, and Younker's service department barely broke a sweat getting it fixed. Again, I thought the cost was reasonable for this service, too, and they did some logical upsells (replace timing belt and water pump), but just mentioned the items and let me decide without pressuring me. The usual mechanic refused to consider using customer supplied parts, but Younker had no problem with that, either.
pumpnethyl
Apr 19, 2017 01:19 PM
shibbershabber
Feb 16, 2014 11:09 AM
meak
May 2, 2009 05:44 PM
garci
Nov 5, 2008 12:18 PM
Spyder
May 13, 2004 04:07 PM
