Sender for 3 Gauges on Dashboard ??
I have removed a set of the three gauges on the center of the dashboardfrom a wrecked Montero Sport and would like to install them on another car.
There's a mechanical inclinometer, an altimiter, and a guage on the left that's blank ..not sure what it is. Can someone tell me. I assume there must be a sensor/sendor unit for the left and right side guages. Can someone tell me where it is located so I can get it? Warren C. |
RE: Sender for 3 Gauges on Dashboard ??
Hi, I know the Oil pressure gauge has its sensor in the block... lower left side (facing the engine). TheVolts gauge should be a wire posted on the alternator...pull the small wire and check to see if the gauge stops working.:eek:
