stalling please help!
I bought a 00 Mitsubishi Montero Sport 3 months ago it ran fine but needed a tune up (oil change, filter, spark plugs and wires) in the process they noticed my valve cover gasket and intake gaskets all needed replaced so its all back together starts right up sits in any gear (park, drive, reverse etc) just fine but soon as it actually starts driving it stalls! Any ideas on what's wrong with it?
Oil killed your alternator?
Originally Posted by keri85
(Post 317609)
https://youtu.be/RhFoFSe1A3U |
No lights on (well the check engine is now)! I heard that they could have I've messed up putting the intake gasket it and over torqued it! Idk its all becoming a pain! I've checked everything else I'm at a loss here!
Check Engine Light is on - what is the code? That will give you a starting point. My guess you have a sensor unplugged or possibly spark plug wires crossed over.
How do I know if the wires are crossed?
Check the numbers on the intake plenum. They show where each wire form the coil is supposed to go to. #1 cylinder is passenger side front of the vehicle, #2 is front on driver side, then 3,4,5 and 6 as the cylinders go.
Ok thanks I will check that this evening!
