Locate the immobilizer on a unit Mitsubishi a Montero 2.5 TD
Old 01-13-2011, 02:57 AM
alclot's Avatar
Question Locate the immobilizer on a unit Mitsubishi a Montero 2.5 TD
Hello friends. I can not find where is the immobilizer in the motor drive of a Mitsubishi Montero 2.5 TD 2002. I step photos of the ecu if you know where it is located.
Just curious. Do you know where it is also the engine management in this unit?
Thanks
Old 01-13-2011, 11:40 AM
Sanguinius's Avatar
Why do you need to find the immobilizer? There is absolutely NOTHING you will be able to do with that piece. To change it requires a dealership to re-code the ECU, Immobilizer, PCM, and ignition switch to be on the same code. Changing it yourself will only end up in a car that will no longer do anything for you.
Old 01-14-2011, 02:44 AM
alclot's Avatar
Hello Sanguinius. This unit has immobilizer but if I change the chip containing the immo I can pass it to another ECU that works for you can start the vehicle. So I need to know where the chip. In the official house Mitsubishi is very expensive solution. Excuse my English and thanks for the reply.
Old 01-15-2011, 08:18 AM
Sanguinius's Avatar
OH you're asking for the specific chip IN that unit for the immobilizer is? Good luck with that. You'd have to have the schematics to find that unfortunately and I don't think there are many automotive manufacturers that are going to just let those schematics leak out and run rampant on the internet.
Old 01-20-2011, 10:30 PM
jgbrules's Avatar
the immobilizer ecu is a seperate unit from the pcm. replacing either of them will result in a no start condition unless is programmed by the dealer
navidbe
11-20-2013 09:17 PM
marianomontero
07-28-2013 08:17 PM
rayp35
12-10-2007 08:14 AM
fool4montero
04-16-2005 10:51 PM
Quick Reply: Locate the immobilizer on a unit Mitsubishi a Montero 2.5 TD
