Strange Dome Light Problem
I have a 2002 Sport 3.0 that has been having some weird dome light issues. The interior dome light will not work both when turned on or when a door opens. However, if I remove the bulb and then place it back in the slot the light will work, BUT (only if a door is open or the switch it turned to the on position when the bulb is returned). Once the door is shut If I take out the bulb and return the bulb with the switch turned off and the doors shut the fuse will blow when the door is opened... This process of working or not working will repeat over and over....... I am really not sure where to start looking..... Any advice is welcomed!
