-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   Stuck in reverse (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/stuck-reverse-57192/)
A.Smith19 Feb 8, 2024 10:47 AM
Stuck in reverse
I have a 2004 mitsubishi montero sport that Is stuck in Reverse. It won't shift into any other gear, including park but the shifter will move. It just won't grab any other gear when moving it. My transmission fluid is fine. Anything helps. Thanks.
SRTx Feb 15, 2024 07:59 PM
Scan the vehicle, but did u check the neutral switch? Other is the solenoid, wiring or mechanical internal issues…
