Throttle Actuator Control Motor circuit high 2003 Montero unlimited
Old Sep 30, 2020 | 02:45 AM
Noahp45's Avatar
Default Throttle Actuator Control Motor circuit high 2003 Montero unlimited
hello Ladies and Gentlemen can I get a little guidance?
So sometimes i would come to a stop and my montero would idle so low it would stall. I would start it up rev it and be fine.
Well today I started up after-work and i started driving got over 20mph and I noticed I had no power. I would push the gas pedal to the floor nothing would happen. I make it home and pull out my scan tool and it says
"Throttle Actuator ControlContrr circuit high "
I cleared the codes and push the gas pedal..instant feedback car revs normal
My question is
is it a fluke?
What should I do?
Thank you in advance
Old Oct 8, 2020 | 02:48 PM
KeshaM.'s Avatar
Hi ...
I have a 2003 Montero Limited, and currently experiencing the same issues when at a stop or in a idle position.
My truck will slowly start to reduce rpm's until it just shuts off. I have to press the gas to keep it awake! Very frustrating because it was driving well until one day this starting happening.
My mechanic said, it is the throttle body need to be replaced. Another mechanic said to check a few things before you spend $$$ on that part. Check the catalytic converter if its clogged. So, i'm in the process of seeing if one of these could be the cause.
Old Oct 9, 2020 | 06:37 PM
Noahp45's Avatar
Originally Posted by KeshaM.
Hi ...
Run the AC and see if it stops running, if it doesn't then its nit the cat
So I put some premium from chevron and haven't had any issues. Im thiking dirty throttle body and crappy gas.
Old Sep 28, 2022 | 09:42 PM
wilde's Avatar
Default Problem return?
Hi. Did your problem stay gone? I'm having this issue:
Random & infrequent throttle control malfunction
I made a post about it just now if you search that. Should come.up.
Old Sep 29, 2022 | 08:55 AM
Noahp45's Avatar
no comes back every now and then I run 93, and I stay away from ethanol. I still get it from time to time
Old Sep 30, 2022 | 05:36 PM
wilde's Avatar
if you turn it off for any amount of time does it reset immediately? How long does it have to stay off before it works ok? Mine resets after 5 to 10 minutes. Almost like it's cooling down and resetting itself.
Have you checked the spark plugs, wires and Injector ohms?
A YouTube mechanic told me to keep a scan tool in SUV and check what the LTFTs are doing if it comes back.
Old Oct 6, 2022 | 06:06 PM
Buster1's Avatar
Wow ! I’m glad to know I’m not the only one. Everyone that had voiced their issue is exactly what I experience. With that said, sometimes I have to unplug the the throttle body pigtail with the truck off, re-plug and then it will rev freely. Otherwise it’s like in a limp mode.
I have replaced the throttle body. It was an inexpensive TB from China. It fixed the problem that was linked to a bad one. It worked fine for another 1000 miles.
Now, I’m not sure if it’s a bad throttle positioning sensor or what. I do know the my Mitsubishi dealer can no longer supply me with this part.
My 2003 limited is a 3.8 L .
ANY SUGGESTIONS ALL?
wilde
Sep 28, 2022 09:38 PM
wilde
Sep 28, 2022 09:37 PM
jay martin
Feb 8, 2013 12:01 PM
N/Teclipse
Oct 15, 2006 10:50 PM
nightseer
Jan 25, 2006 01:14 AM
