Timing belt parts list 1999 3.5 Monty
Here are the parts that I am going to order from Rock Auto.
GATES Part # TCK287 {3 Components (1 Belt, 1 Tensioner, 1 Idler)} Interference engine application; Does not include cam. tensioner hyd. assy. $53.79 each BECK/ARNLEY Part # 1312298 Water pump W/Housing $109.79 3.5 SOHC 170K miles Do I need anything else? Mike |
Can't comment on the suitability of those part numbers (I used Mitsu parts) but are you also planning to change the water pump?
This is usually advised when changing belts. Ron |
Cam seal and crank seal. You only want to do this once.
Any special tools for the cam seal and crank seal?
Hey Ron, you have a PM. Mike |
Mike.
I replied to your PM with some info. Ron |
