Tps ?
Old Sep 1, 2018 | 11:57 AM
Tadow17's Avatar
Default Tps ?
What is the procedure for adjusting the throttle position sensor on a 2002 Mitsubishi Montero Sport 3. 0 two wheel drive?
Old Sep 21, 2018 | 03:44 PM
Rhett66's Avatar
Default TPS adjust
Disconnect neg batt cable(s) then disconnect TPS and MAF connections.
Adjust TPS all the way counter clockwise and tighten it up. Plug connections back in then reconnect neg batt cables. Timing should be about 10*
you can get a print out at autozone for this. Hope this helps.
MyLittleBlackBird
Dec 20, 2005 12:16 AM
monkey
Aug 27, 2005 03:07 AM
FARDJA
Jun 28, 2005 11:05 AM
MX6GT
Apr 8, 2005 06:15 PM
Vetter
Nov 22, 2004 10:44 AM
