Transfer Case Drain Plug ??
Hello,
I want to change the transfer case gear oil (yes, GL-4) on my 2005 Montero Limited, but I only see one plug on side of the transfer case and I assume this is the fill plug. Don't see a drain plug anywhere? Do you suction out the oil via the fill plug? Thanks, Rob |
RE: Transfer Case Drain Plug ??
what does your repair manual say ?????????????
ORIGINAL: mototools Hello, I want to change the transfer case gear oil (yes, GL-4) on my 2005 Montero Limited, but I only see one plug on side of the transfer case and I assume this is the fill plug. Don't see a drain plug anywhere? Do you suction out the oil via the fill plug? Thanks, Rob |
