Transmission Oil Filter
Hi, I have 2001 Mitsubishi Montero Ltd. I am trying to find out original part number for the transmission oil filter.I need change the oil inside automatic transmission, but I can not find the original part number, that I could order on-line. Thank you very much for help.
If you're ordering online, just select your vehicle, choose the part that you want and provide your VIN number so they can match it to the part. If you're willing to go aftermarket, there are quite a few decent filters out there.
Hi Skiddy, thanks for answer. I visit web site www.mitsubishiparts.com, but I did not find automatic transmission oil filter. Do you know some other web site? Thank you.
Musi_oci,
If you select your vehicle (2001 Mitsubishi Montero), then click on Maintenance & lubrication on the left hand menu, you will see a transmission section. Click on that, then click on Automatic transmission. The filter is on the list there, costing $13.90. Hope this helps. :) |
