Weird problem, 4Wheel light indicator, passenger rear NOT on, but no error codes
Weird problem, earlier I had to brake really hard and the ABS went on.
Soon after I noticed the 4wheel indicator, which was just set to normal RWD operation, only had the driver side green tire on, but the other was not. I switched to different 4wd modes and everything worked normally but the light still did not turn on. My ABS light did not go on, nor did any check engine or brake warning lights. Could this just be the bulb in the indicator going out? |
+1 on the burned out bulb. They don't last forever.
Swap it out with the either the "2" or "L" bulb in your shift position indicator if you don't want to buy a new bulb just now. Ron |
I fixed the problem, I just hit the dash with good force and it came back on. lol.
Originally Posted by redturboeclipse
(Post 255445)
