wet carpet on the driver's side
Old 01-30-2006 | 02:28 PM
dswa5's Avatar
Default wet carpet on the driver's side
I think I saw someone post some information on what to do when water gets in on the driver's side floor when it rains. Any insight on what I can do to prevent this from happen again. (2003 Mitsubishi Monterro Sport LS)
Old 02-01-2006 | 01:04 PM
off roader's Avatar
Default RE: wet carpet on the driver's side
In Gen I's, It usually leaks through your windshield gasket or possibly from the hoses going to your heater core. Does the water smell like coolant at all? If it does then it will be those hoses. if not, then it's probably the windshield gasket.
HTH>
Old 02-01-2006 | 06:06 PM
dswa5's Avatar
It doesn't smell like coolant, so what do you recommend to fix the windshield gasket?
Old 02-01-2006 | 10:42 PM
off roader's Avatar
Maybe... assuming you've exhausted all other possible areas where it could be leaking. For example, it could be coming from a sun roof, door leak, etc.
Also, I'm not an expert on your model so I can only say what I know about my model montero (1990 4 door v6)
Old 02-02-2006 | 02:02 PM
dswa5's Avatar
When it rains, water tends to get in on the driver's side on the floor.
Old 02-02-2006 | 08:51 PM
off roader's Avatar
From your description thus far, it sounds like a new windshield gasket is needed.
Not sure how well this will work but seems logical that it will.... others may have other idea's as well.
(note: it's no guarantee that it will work but if you do see water inside when doing this, it will help you isolate where the problem is.)
1) Dry it all out... Fully.
Remove as much of the carpet from the side that get's wet as you can (means removing the front seat, some trim panels, etc. on that side)...
Make sure the floor's dry.
Close the door, and have a friend spray water on the car in one spot for a few minutes and check for water inside.
If you don't see any water after a few minutes of spraying, do it again in another spot for a few minutes. You need to do it for a few minutes at each spot because it may take some time for it to leak in and flow to the floor where you'll be able to see it.
HTH.
Ray
Old 02-23-2015 | 10:23 AM
mlduncan96's Avatar
Anyone ever resolve this issue? I am noticing on the plastic at the bottom of the door after rain. The amount is small, but it were larger I could see it getting to the carpet. I looked over the door seal and didn't see anything obvious, but it appears to be coming in/through/around the door on my Montero - 02 XLS.
TechnoGeek
07-12-2014 11:04 AM
dott
06-24-2009 05:53 PM
eduardob
03-12-2009 09:57 AM
aribo
12-26-2008 04:57 PM
bishigt_18
11-01-2008 07:24 PM
Quick Reply: wet carpet on the driver's side
