-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   what type antifriction grease is used in our turnsignal switch (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/what-type-antifriction-grease-used-our-turnsignal-switch-56520/)
PalmSprings Nov 22, 2022 03:35 PM
Ihad to replace my turn signal switch assembly on my other 01montero sport (@ .(150K ).
.because the right turn signal would remain on all the time the ignition was on...couldnt shut it off unless I held in the flasher button. (FYI: My other one with close to 240K ,works fine, since new.)
My question : what anti friction white lube is used in the switch ? I can easily see white grease in the one I replaced but the new one either doesnt have any,or is hidden from view even after I moved the handle a couple times. I cant be certain it was pre lubed now . There was no information about it.. and it comes from Tiwan thru amazon.
The one I removed had it all over the visible parts that were in contact when moving the signal "stick"
How'bout lithium? That may be what I choose if nothing knew is learned . How about teflon white grease. I have a 1/2 cup of it already. Itd be nice to not be stuck with more white grease I rarely use
