No Fire
No Fire
Ok guys, I have 30 lb. of fuel on the fuel rail.. starts only with starting fluid.... I have 12 volts constant for the fuel injectors.. ?????????????????????????????????????????????????? ???????????????? Computer is new.. Injectors are new.... Puzzled....
12v constant on fuel injectors is the issue. You suppose to have square wave signal on injectors. I can't confirm is it should be 5v or 12v though. Are you 100% certain that PCM is the right one for your engine?
Tried the old pcm and put a new pcm on it with the same issue... if i put a stethoscope on it you can hear the click that the injectors are opening and with 30 lb. on the fuel rail I am totally stumped.. I checked the schismatics on it and it should have 12 volts all the time and the negative side goes to the pcm...I D K... Thanks for any input....
