Can't remove rear cam seal plate
Old 03-12-2018, 04:44 PM
taybrynn2's Avatar
Default Can't remove rear cam seal plate
I have just completed the valve cover gaskets and was going to replace both rear cam o-rings.
I was able to remove both 12mm bolts ... but then cannot get the plate to budge (can't rotate it at all).
I suspect the plates both have some sealant on them, as something white is visible around the edge
of the plates... how do I proceed?
Thanks in advance!
Old 03-12-2018, 05:20 PM
I know there is not much space to get there, but have you tried a rubber mallet or a small hammer and a block of wood?
Old 03-12-2018, 06:03 PM
taybrynn2's Avatar
no, I just used my hands ... so the block of wood sounds worthy of a shot !
Old 03-12-2018, 08:35 PM
taybrynn2's Avatar
Thanks again!
For the passenger side:
Per your suggestion, I used a 2x2 wood block.
Wow, it was totally shot (brittle) and some kind of white colored sealant everywhere thats taking forever to clean off.
For the drivers side:
Used an old wood screwdriver and a rubber mallet to get the driver side off, which was more difficult but not horrible once I found that the screwdrive was the only thing narrow enough to engage the plate with. O-ring totally flat and busted off and was brittle. Sings of oil leak everywhere.
Should I use an RTV on the flat surfaces when I re-install it? If so, any recommendations? I have permatex ultra black but have never used it.
Old 03-13-2018, 04:34 AM
larry4406's Avatar
I think RTV here is a hack repair, use the correct OEM O-ring.
Old 03-13-2018, 07:15 AM
taybrynn2's Avatar
I agree. I have purchased two OEM o-ring (s) and intend Install those ... without additional sealant unless there is some benefit to using sealant also. It’s a lot of work getting the crap off, which appears to be a hack job unless that was original?
Old 03-13-2018, 04:12 PM
100% agree
Media001
01-02-2015 03:28 PM
AKMontero
01-31-2012 10:17 PM
aps13
07-03-2011 03:34 PM
wrkrbee
10-16-2010 02:04 PM
monterodude
04-27-2005 09:52 PM
Quick Reply: Can't remove rear cam seal plate
