dej73 |
05-07-2013 07:27 PM |
thanks!!! little bit hard to do it, theres a youtube video how to remove the lens and to
install the leds very trick specially had a heater on the mirror, you must need a hair blower to remove plastic on the mirror. you going heat up the edge of the plastic and slowly to bend it, make sure dont scracth the back of the mirror, if you have a heater the same process heat up on the edge and pull it slowly into halfway then thats you can put leds. About the wire, open the door and remove the tweeter, theres three nuts to remove also, now you can easy to way out the wire and then wire going to signal light on the fender and tap it there. Thats it!!!!
