-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   2007 Outlander exhaust question (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/2007-outlander-exhaust-question-50797/)
yel Apr 20, 2017 04:48 PM
My 2007 Outlander needs a new catalytic converter and pipe (#3 on Mitsubishi page), but is not worth putting $650 into dealer replacement. It looks like magnaflow 51539 ($500) is the cheapest stainless aftermarket replacement. Anyone know of anything cheaper, even if it is steel. Thanks.
Sic_Lucky Apr 20, 2017 10:38 PM
Try this Exhaust Manifold w/ Catalytic Converter Pair Set of 2 for Mitsubishi Outlander | eBay
Both cats for below $500
yel Apr 21, 2017 10:36 AM
1 Attachment(s)
Thanks for the link, it turns out my catalytic converter is fine, it is just the intermediate pipe that I can not find available in steel or aluminized steel. Which is #3 on this page from Mitsubishi.
http://www.mitsubishipartssource.com...ze/6251180.jpg
I can only find it available in stainless steel like here:
It looks like I will have to have it made at a muffler shop if I do not want to pay $500.00 for a stainless version.
dallasneon Apr 25, 2017 02:53 PM
This what you need?
https://www.carid.com/eastern-cataly...84&url=1324153
copyboy311 Oct 4, 2018 01:50 PM
Question on this diagram: The mid pipe (part 3) -- is that a catalytic converter at the front of that pipe or just a resonator of some sort? I had some custom exhaust work done and they cut that piece out completely and just put in a new section of pipe to replace some that was bad. And apparently this part in question was bad too because it's gone. I can't imagine you could just eliminate a converter without consequences, nor would a reputable shop even attempt it. They told me it was a resonator and that the converters on the V6 are up at the manifold, but seeing some other diagrams and descriptions, I am skeptical. So far I have no check engine light, but I don't want any surprises when I go in for an emissions check.
Careful Dec 1, 2018 12:34 PM
Thanks!!!
Edit: "OUT OF STOCK - Unavailable until further notice" Damn it.
Careful Dec 1, 2018 12:36 PM
There seems to be an O2 sensor coming out of it on mine, so I think cat.
copyboy311 Dec 2, 2018 10:15 AM
Do you have the 4-cylinder or 6? It would be a different setup. And although the part they cut out of my exhaust may have been a third converter, if it had an O2 sensor, cutting it out of the system would activate the check-engine light. I have no CEL. I've been meaning to go back to the shop and ask what they did, but I've had no problems since the repair and also I'm lazy.
Careful Dec 2, 2018 10:47 AM
I have the 6.
copyboy311 Dec 4, 2018 07:35 PM
So I did ask the shop, and yes, that is a 3rd cat converter; however, it is not connected to an O2 sensor, so it does not relay any info to the ECU and thus will not trip any check-engine light. They insisted it would pass an emissions test as well. They never asked me if it was OK with me to cut it out. Shady? A little bit, yes. But I'd still choose that option over replacing with the factory part that cost 4 times as much. The car is 11 years old.
