2007 outlander II noise on bumps
Old Jul 24, 2014 | 09:14 AM
dokthor74's Avatar
Default 2007 outlander II noise on bumps
Hello, i have 2007 outlanderII and i hear "metal kind" noise on front left wheel when driving over a small bumps, but when i hit brakes the noise stops. Did anybody had same problem?
Old Jul 24, 2014 | 01:22 PM
ccernst's Avatar
Could you give some more information?
For a long time, I've had a creaking noise out of my front right suspension that I've determined to be the strut bushing. It creaks as I turn or go over small bumps. It is not the ball joint as I routinely get alignments and they have not piped up about that going bad.
So you hit a bump, the noise starts until you hit the brakes? what if you are braking as you hit the bump? Does turning play a part?
Old Jul 24, 2014 | 01:59 PM
dokthor74's Avatar
If i am braking when i hit the bumps the noise does not appear. If i turn, there is no noise, only over a small sharp bumps. Its like a mistery, my mechanic examined everything - as he said - and he didnt found anything... but what i hear is like something is about to fall apart
and i like my car a LOTT
Old Jul 24, 2014 | 03:22 PM
Claude_A's Avatar
Loose brake pad missing or broken or misinstalled retaining clip.
I had that on a Chrysler product which share a lot of brake component and layout with Mitsubishi.
The pad rattle in the holder when retracted but will not when under pressure as they contact the disk.
Old Jul 28, 2014 | 12:54 PM
dokthor74's Avatar
Thanks, it was a pad.
Chef
Sep 26, 2014 05:22 PM
sloopjoshc
13
Apr 5, 2011 03:57 PM
AlX0423
Nov 3, 2009 06:46 PM
klas
Jul 8, 2008 06:28 PM
BptEclipse
Jun 27, 2005 07:21 PM
