2007 Outlander Rear Left Window
I have a 2007 Outlander. The rear driver's side window came off track. The arm that lifts the window up has a ball on the end of it that attaches it to the track. There is a plastic piece that guides the ball inside the track. That plastic piece has snapped in half. What is it called or what is the part number. Where can I order it from?
Don't know the part no.,but you should be able to go youy local Mitsu dealer and ordeer one . The parts people should be able to find it in their parts breakdowns.
I think you have two options.
- 2007 MITSUBISHI OUTLANDER Parts - Mitsubishi Parts | OEM Mitsubishi Parts | Genuine Mitsubishi Parts ## I think the regulator is what you are looking for. - I've had relative success repairing regulators on my old Pontiac Grand Am. I used two-part epoxy and braided steel cable. Depending on how it broke, you can wrap the steel around the part, then coat it with epoxy...makes a rigid cast of sorts. |
Youtube video fix
There's a good video about this problem with a 2010 Outlander:
| All times are GMT -5. The time now is 08:14 AM. |
