2007 Outlander Wind Noise from front left window
I have 2007 Outlander and my problem is about noise:
What I've notices is that as the window is raised and hit the top stop the glass deflects out slightly. I assume this must be reducing the force on the window seal and causing cabin noise, if i lower the window a fraction (so still closed but just off top stop) the noise reduced to a more acceptable level. Has anyone else experienced this window seal issue. Is there a know fix of it. If you do suffer from side window wind noise try slightly lowering the window and see if that has an effect. If its possible could somebody sent the picture of how did you manage to solve the problem. Thank you. |
I fix the problem with this method:
Fruscio aerodinamico dagli specchietti esterni. |
| All times are GMT -5. The time now is 08:38 AM. |
