2008 Foglights
Has anyone replaced the fog lights on their 2007-2009 Outlanders? What bulb type do they use? How hard is it to replace the bulbs?
It's simple as.. I upgraded to hid bulbs and very simple to do.. The only tight spot is rh side with water bottle otherwise you can easily slide your hand through guard and headlight to access or simply remove undertray
What bulb type/size for the foglights?
H9 is what men use but H11 is the same afaik
What are the brightest and best fog light bulbs available for the Outlander? Brand/Link?
Tbh I just bought the $30 eBay ones and using a 6000k bulb temrature.
Just want to make sure do you think these would fit the foglights? PUTCOŽ 230011NB - Halogen Replacement Bulbs (H11, 6000K) Thank-You!
Yup, not keen on hid? Lol
When you say hid is that xenon or totally different setup that requires upgrades in order to use the bulb? I wanted to know if anyone knows the best Philips h11 bulbs?
I am at best buy they said the 2008 Mitsubishi Outlander XLS fog light bulbs are not h11 so what are they?
| All times are GMT -5. The time now is 08:47 AM. |
