2 Attachment(s)
I installed a razo pad set. It was universal kit but it is amazingly looking good.
jsrd have you installed the sun visor with light bar yet? Where did you wire it to? |
1 Attachment(s)
Yes, I am preparing the writing of the installation
Attachment 6935 |
Hi JSRD,
do you made changes to the arm? is that it's very complicated to do? |
Hi Ian, I don't removed the arm, I drilled one small hole in the center pedal, removed the one black plastic piece from aluminum pad and fitted it with screw to accel pedal; then, I covered the screw head with same black plastic, just is 0k for me :)
2010 wiring diagram for Combination Meter
Hi. Someone have 2010 service manual and can share information? I need the wiring diagram for cluster or combination meter with color screen (METER AND GAUGE SECTION) to see if the harness is compatible with 2007 model to do the "update".
Thank's in advance :) |
That would be a great mod. I don't see why it would be a different connector...they display the exact same information. At first I though the S-AWC system was a requirement for it, but even the Lancer GTS FWD has the colour MFD.
I agree. I have the part number, price and clusters is available in stock, but I want to be sure that I will not have problems to do the change; for this reason I would obtain the wiring diagrams first or the help of forum member
Originally Posted by jsrd
(Post 259928)
Meter and gauge diagrams found. . .
