AC Evap Drain Location on 2003 Outlander pics
After scowering the internet for a week now to try to find any info i could on the location of the AC Drain i decided to go in and find it myself after coming up short handed. You will need to remove the air filter housing to get a good view of it as i found it impossible to get to from under the car. The power steering rack and k member where in the way. You need a 6mm ratchet to disconnect the 2 bolts that hold in the air filter housing and the bolt that tightens the house to the throttle body. At that point with a flash light the AC drain can be seen.
Thanks. I had this problem once before and paid ac shop 100$ to clean it out because I couldn't find the drain. This picture and recommending moving the air filter housing was just the trick. I was able to shoot some air in and it starts draining right away. Total time from start to finish was 20 minutes. Thanks for this entry.
Bearwater
08-22-2005 12:22 AM
2003, ac, air, clean, conditioner, conditioning, drain, drains, evaporator, galant, housing, located, location, mitsubishi, outlander, raider
