2011 Outlander Sport Bad Gas Mileage?
#81
I now have 5600kms on my rvr.... went from revelstoke to golden and back and to vernon, display showed 6.7 L/ 100Km.....my manaul calculation was 41.7 mpg (imperial gal), this is 99.9% highway driving around 90kmh to 110kmh. This is using regular petro canda fuel. Had my first oil change at 4400km...mitsubishi 0W20 syn. oil was added to crankcase. Also I am driving in 2wheeldrive mode.
#83
The Results
After completing the second road test (88KM) I cannot argue the fact that the car got the advertised economy. We drove on the highway and through town, with cruise control and A/C. We managed to get 6.3/L 100K or 44.58 MPG. Which is excellent. So I would feel like a complete idiot except for one variable. When we filled up the car, we were able to put an extra 10 litres in fuel into the tank after the nozzle clicked off!!! I watched amazed as the car kept on drinking it up! So with this said there is a 0-10 litre varaible on fill ups. For example I fill the car up to what i think is full and drive 400K and then fill up again to what I think is full but this time the car takes an extra 7 L due to whatever circumstances as pump speed, tank pressure or temperature, well that is going to greatly reduce my fuel economy, when in fact the car is just accepting more fuel. With this said we have filled the car until fuel is visible at the fuel hole and I will fill up again the same next time and will post results. My driving range is apparently 750KM!!! with the tank filled to capacity!
#84
My last tank average was about 23mpg. A little lower than I thought but not bad. It seems to be getting better as time goes on. For a test I put premium in on the last fill-up and that has really knocked my gas mileage down. Getting about 20-23mpg city. (5 mile trips here and there over the holiday weekend). Will post again at the end of this tank. ( I just added a roof kit which includes rails and crossbars) for my kayaks which will most likely reduce my numbers but hopefully not too much.
#86
Just did a 900+km trip over the long weekend, results were decent. The trip wasn't completely flat, lots of hills and uphill sections.
8.4L/100km avg, with AC on, 4 adults, luggage and a cooler full for drinks. No where near the advertised 6.6L/100km highway, but given factors i'm happy.
I actually prefer driving with the tiptronic/paddle shifters than CVT mode. The RPMs are only slightly higher in 6th than in CVT mode, but the ability for it to hold the gear actually makes it better. Also I find downshifting to 5th to pass or accelerate quicker and more fuel efficient than letting the CVT hum away. In 5th you get it done faster and I feel using less fuel, in CVT mode it takes too long, the RPMs go higher and it just feels like it took longer and ate more fuel.
#87
Maybe so, but I am trying to do an accurate test over an entire tank of fuel and as I said before there is a 0 to 10 litre variance from the time the nozzle clicks so it is the only way to do an accurate test over an entire tank.
#88
Those are pretty good numbers considering the loaded vehicle. I will post our results when we get them, it's some time between tanks for us.
#89
By filling to the brim you are risking harming your emissions control system which may throw a code and cause the service engine light to come on.
I only ever fill it to the first click at a pump. The back pressure of the fuel against the nozzle shuts off the pump and I would think this is rather consistent unless it is clicking off all the time during your filling.
http://auto.howstuffworks.com/gas-pump5.htm
To limit the variation in your fillups you can try using the same fuel pump at the same station at the same time of the day - mornings are much cooler and temperature affects liquid volume which is why the pumps are volume corrected to a specific temperature.
#90
Disgusted with MPG!!!
I have the SE 4WD and always have it in 2WD and have it for almost 3 mths. I live in Florida (VERY FLAT)... I am lucky if I get 18 mpg! I've already brought it into the dealer once and I was told they got 25 mpg on the hwy - which is still way less than what it should get on hwy. I am going to call them tomorrow again because the entire reason I bought this crossover was because of the mpg on the sticker.
Otherwise, I like the vehicle but I am seriously considering getting rid of it if this is the mpg I will be getting. It's not worth it to me! Plus I feel like they've lied about the mpg which totally sucks!
It sounds like I'm not alone in the crappy mpg the Sport is getting either which is disheartening. This is the first and list Mitsubishi I will ever buy.
