2011 outlander xls fast key not unlocking door???
It should.
You are actually holding the handle are you?
Default setting is
Hold the driver door and it beep twice than open just that door.
Hold the passenger or the hatch and it beep twice than open all doors.
Door opening can also be disabled in the ETACS.
It's new, go back to the dealer, all adjustment should be free for a year.
Default setting is
Have a look around page 3-49 of your owner manual.
If you have the MMCS use the screen otherwise it's the button dance on the remote.
You also will probably have to do it more then once as the options are changed in sequence.
Don't forget to set the parking brake.
Ok i try, and even dealer say it not like that for the 2011. Anybody else can try for me ? lol
Even manual, say that to unlock door i need to press the button ? Why the 08 work, your 2010 claude_A Also do that, why did they took that option out for the 2011 ??
This is the setting option in the ETACS from 2007 to at least 2010 (The attachment).
The default was open all. Unless they are afraid of hacking the lock I dont see why but the dealer can change it for sure. Just bug him.
I guess the new default is Start only
but im sure it is, lol, its the same system, why they will have take out a feature ????
Any one with a 2011 arround ? That when you touch door, door unlock ?
I did setup my vehicule so when i unlock door, they all unlock, but still i need to manualy press the button to unlock door on the door andel.
Who is that marvelous dealer?
It's probably not that they cannot but they might have instruction not to.
Or he has no idea how to use the Mut 3.
Try phoning Mitsubishi office the number is in the owner manual.
