2017 Outlander GT - rear brake issue
hello everyone my wife’s outlander needs rear pads and rotors. She has 30K miles. Pads are literally done. However, when my father went to change them, the calipers weren’t releasing. He said something about not being able to put the piston back in. He seems to think either the caliper is faulty or the Electronic Parking brake is activating (car is shut off, e-brake not on). cany anyone help? i don’t wanna go to the dealer because they charge too much for labor. thanks |
The vehicle is under warranty...If the calipers or e-brake are causing the pads to wear..which has to be the case at such low mileage..they should fix it with no problem...push them a bit...NO Way rear pads can wear that fast, Best of Luck!
Check if he's using a tool to wind the pistons back in as shown in this article.
https://www.autozone.com/repairinfo/...96b43f8036fc2f |
The dealer said there was nothing wrong with the calipers. It’s normal wear and tare. I will be opening a case with Mitsubishi because I’ve never heard of brake pads wearing out at less than 30K miles. |
Originally Posted by erixon84
(Post 325220)
Contact Mitsubishi Corprate
If I were you I would contact Mitsubishi Corporate on the phone and raise hell.
Hi erixon84,
My 2017 outlander GT rear breaks were worn out at 30000 miles as well. What is the outcome of your case? |
Mitsubishi Outlander 2017 brakes
Originally Posted by MCK
(Post 329007)
Hi erixon84,
Hi All,
I did my rear brake pad replacement on the 2017 Mitsubishi Outlander GT AWD and the EBP service light is coming on. how to reset it and any tool to reset it? |
Did you put the braking system in service mode first? Or did you force he pistons back in to the rear calipers?
