2018 Mitsubishi Outlander passenger side reverse light is not getting power
I have a 2018 Mitsubishi Outlander I bought new April 2018. Issue I have is my passenger side reverse light quit working. Ok first thing I done was replaced the bulb. 2nd thing I done was swapped bulb around to the other socket on the driver's side just to make sure it wasn't bad also. It worked in the driver's side. 3rd I checked fuse's all were good under the hood and in passenger side front kick panel. 4th tested with a tea light.
With all of that being said. I'm not getting power to passenger reverse light socket. Before I go tapping into the driver's side and just running a new wire. By any chance has anyone else ran into this issue? And successfully fixed it without just running a new wire? It's wife's car and because it's the first new car we have ever bought. I really don't won't to have to rig it by tapping into the driver's socket and running a new wire to the passenger side. I only do that on my beaters that I don't really care about.
Thanks in advance for any help and solutions.
I'm pretty sure both are supposed to be reverse lights. Other wise my wife would have noticed it not working sooner. When I get home. I'll check it out and see if it comes on with the fog lights or not. But I've never known any vehicle to have a rear fog lamp. Other than the ones I normally wire to reverse and a toggle switch for my warning of tailgaters. To me a rear fog light would do nothing but blind the people behind you. Witch is probably illegal. Witch is why I don't believe I've ever seen a rear fog lamp on a vehicle before.
A rear fog light shows red, not white light. Mitsubishi only produce 1 harness for all countries, that s how here in australia we have rear fog lights when they are not a requirement by law. Its acceptable to buy another reverse light lens and swap it out for the foglight one , but some people do this expecting it to work automatically, but you have to wire it to the other side. I have also seen people do it for aesthetic reasons, as it looks odd having red on one side and white on the other.
Dtscott86
07-31-2022 03:19 PM
