-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Anyone in the Concord NH area have a Mut III I can hook into my Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/anyone-concord-nh-area-have-mut-iii-i-can-hook-into-my-outlander-46197/)
allwayshvac Mar 18, 2014 04:39 PM
I have a 2007 Outlander with what my mechanic called a failed ETAC for the front wipers , we tested all of the wiper motors and the switch from the column and no dice out of the etac to the wiper motor , he didnt have a mut III to bypass the relay in the etac , but from what I have heard is you can ByPass the etac ? Any Help on this would be greatly appreciated .
Patrick
boogunoogun Mar 19, 2014 03:53 PM
1 Attachment(s)
Do you have rain sensitive wipers?
I have the Actia tool with ETACS Decoder. Not sure if you can "bypass" the relay via the etacts. I can program it to
Normal INT
Variable INT
Speed sensitive
Rain sensitve
(above when the column switch is in the on position)
Did you test all of the wiper related relays? check for proper resistances to ground from the column switch? Even try pulling the battery out for a few minutes to reset the system?
Attachment 2665
I suggest you download the service manual as well. A lot of good info in there.
See section 51-25 through 51-65
I am located North of Boston. PM me if you want to drive down here for help. We can meet up.
I travel your way during the summer....but we are still far from that :cool:
Attachment 2665
Vadimus Mar 19, 2014 03:57 PM
Originally Posted by boogunoogun (Post 300419)
Not sure if you can "bypass" the relay via the etacs
Never heard anything like that.
