Bluetooth Issue
Old Dec 6, 2013 | 08:41 PM
SERPENTOR's Avatar
Arrow Bluetooth Issue
I have a 2008 Mitsubishi Outlander XLS with the Factory Navigation setup. My Bluetooth does not respond at all. I have tried pressing all three buttons to use it and nothing works. Does anyone know what could be wrong and how to fix it?
Old Dec 6, 2013 | 09:01 PM
Vadimus's Avatar
What happens when you initiate the call from MMCS screen?
Old Dec 6, 2013 | 11:48 PM
SERPENTOR's Avatar
When I use the MMCS it just shows no bluetooth phone connected so theres that x on the screen and no bars or battery life icon. When I try to use the Bluetooth command buttons there is no response.
Old Dec 7, 2013 | 08:18 AM
Vadimus's Avatar
Check BT unit connections. It is behind AC controls, plastic box under MMCS.
Old Dec 7, 2013 | 06:24 PM
milliesdad's Avatar
Could also be clock spring?
Start by checking continuity and maybe re-pair your phone. This would happen occasionly with my Android with my 2010 Outie.
Old Dec 7, 2013 | 07:03 PM
SERPENTOR's Avatar
Connection of the wire is good. I can't not start the pairing process because the Bluetooth voice command buttons do not work.
Old Dec 7, 2013 | 07:42 PM
elboy0712's Avatar
Try a Mitsubishi dealership!
Old Dec 8, 2013 | 09:19 AM
milliesdad's Avatar
I think the OP is looking for help, not comic relief
Did you check fuses and such?
Old Dec 8, 2013 | 04:30 PM
Vadimus's Avatar
Hardly. It would be still controllable from the MMCS.
Old Dec 8, 2013 | 07:59 PM
SERPENTOR's Avatar
Checked the fuses they all look ok. I am wondering if the Bluetooth Chip might have just burned out. If so would I need to replace the whole MMCS unit? Does anyone know how much a repair like this should cost? Will be going into the Mitsubishi Dealer want to have some prices in my head so I do not get ripped off.
