Bluetooth System Error
Old Feb 5, 2012 | 01:00 PM
nige02's Avatar
Default Bluetooth System Error
I,ve had my outlander for 6 months with no problems, until recently the bluetooth stopped working. When I touch the mobile phone symbol on the touch screen, it displays 'system error' message.
Is there something I can do, or is this a job for the laptop at the mitsubishi garage?!
Any response would be appreciated, thanks Richard.
Old Feb 6, 2012 | 10:03 AM
sfinney76's Avatar
I bought a used 2007 Outlander XLS with the MMCS and the bluetooth worked fine for about 2 weeks and then stopped working for no apparent reason. The only thing I can think of is, the day before it stopped working I plugged in my cell phone to the rear audio inputs to play internet radio. Ever since then pushing the phone button on the steering wheel does nothing and my phone will not pair anymore. Maybe our 2 problems have a common cause.
Old Feb 6, 2012 | 08:58 PM
ivanz's Avatar
No, they have nothing to do with each other directly. To damage the bluetooth module, you would have to damage the stereo.
Does MMCS see your phones/BT module still? If not, try taking out the MMCS unit and ensure the bluetooth module is plugged in correctly (its below the MMCS). Could have just come lose...
If not, you can buy a replacement unit and its plug and play. Although I've never heard of the unit failing...it must be some wiring/connector issue.
If it still works, then its a steering wheel control issue. The controls go through the stereo, so it could be the culprit. However, all the steering wheel controls go through one wire, so none of them would work.
Old Feb 7, 2012 | 04:28 PM
nige02's Avatar
Hi, sorry for the dumb question, what do you mean by MMCS?
Cheers Rich.
Old Feb 7, 2012 | 07:54 PM
ivanz's Avatar
The navigation system/stereo. Its right under it...looks like a rectangle with a bluetooth logo on it.
Old Feb 10, 2012 | 03:27 PM
kweegibo's Avatar
Default 2007 Outlander - My handsfree system stopped working as well
My bluetooth just stopped working as well.
When I go to hit the button on the steering column, I do not get any response.
Everything else works. Sirius, MusicServer, etc..
Old May 27, 2014 | 10:16 AM
hkm's Avatar
hkm
My bluetooth responds some time but then an empty battery sign appears and it just disappears. When I try again nothing happens.
Can some one help please. I have Mitsubishi outlander 2008
Old May 28, 2015 | 10:59 AM
wiseowl's Avatar
I know this thread is abit old but if this info helps anyone.....
I had a problem with my phone bluetooth it that sometimes it would work and sometimes it would not.
When it would not work there was no response from any of the steering column buttons.
When it did work i would usually get as far as "dialling" and then it would switch off.
In the end I bought a new bluetooth module and it has been perfect since.
So despite reading on the internet that "these units dont fail" , they obviously do.
Hope this helps someone.
Old Jun 1, 2015 | 01:49 PM
NEILFAUX's Avatar
Hi can you advise where you purchased the replacement unit from please and how much ? thanks
Old Jun 2, 2015 | 04:51 AM
wiseowl's Avatar
I was lucky and saw one on Ebay from a write-off. £32.
The new ones are a ridiculous price.
