Can you program a set of TPMS yourself?
http://www.mitsupartsworld.com/Endea...tsb1131001.pdf
It seems maybe you don't have to use dealer for this if you have one of the tools, called a MUT 3? But it's super expensive :) In this article Commonly Available TPMS diagnostic tools If you search the Internet, you will find a number of TPMS diagnostic and service tools. In many cases, you can find complete kits to handle all of your TPMS needs. MMNA does not endorse these tools, but if you are doing regular TPMS service, they may be of interest to you. The circular magnet (p/n 46716, photo right) is an “essential” tool for TPMS sensor registration and is the only tool required by MMNA. It can only be used with TPMS sensors p/n MN103033 (2006 Galant & 2004−06 Endeavor) and MN103081 (when used on Montero only). Aftermarket electronic TPMS tools may provide both sensor registration and activation functions. The following TPMS sensor tools are compatible with all MMNA TPMS equipped products. OTC TPR BARTEC Wheelrite Tech 300+ While these tools are compatible with all current MMNA TPMS equipped vehicles, they are not essential tools. They are NOT available through the Mitsubishi Special Tools website. MMNA does not endorse their use. Other tools may be compatible with MMNA products. Contact the individual vendor for tool capabilities, prices and availability. Some aftermarket electronic TPMS tools are capable of activating TPMS sensors for registration without tire deflation and inflation. Some aftermarket electronic TPMS tools can check for correct sensor frequency to verify the correct sensor is installed. This function is available on the OTC and BARTEC TPMS tools. Certain aftermarket electronic TPMS tools can provide sensor ID, temperature and tire pressure. Valve core tightening tools, some with pre−set torque, are available through independent sources. They allow you to tighten the valve core without risk of over tightening. |
Originally Posted by OutlanderGT
(Post 296882)
However I wasn't able to do anything useful with it. |
You could buy the alligator programmer and buy the matching sensors. OR just email this guy
TPMS Sensors FS - Programmed for FREE - EvoXForums.com - Mitsubishi Lancer Evolution X Forums I bought my sensors from him. All you need to do is go to a tire shop. Have them put their TMPS reader up to the tire valve. Write down all 4 serial numbers. Then email this guy the numbers. He will ship you (very quickly too) 4 sensors programmed for your car. So now you never have to buy mitsubishi sensors or have the stealership charge you money for the programming. I mostly love it because when I switch to my winter rims and tires I do not need to do anything. the outlander's computer thinks it is the stock sensors! |
So what was the budget? Something between $200 and $300?
$250 pre programed. they work mint. I just changed over to my winter rims and tires yesterday. it works flawless. It is like nothing ever happened!
I got a set off ebay (sensors) dealers charged me $20 to reprogram them when i pulled my winter wheels off. took them 5 min
Except now you have to go back every winter and spring to get your car reprogramed
100% but for $20 every 6 or so months, that is really not that bad. i have not seen a Mitzu II under $250 so to me that levels out. Plus the dealer is at the end of my block so it is just up the street and i get a free car wash out of the deal! hahaha
