-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Convert a 2008 to a 2010 (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/convert-2008-2010-a-34393/)
ark_royal Nov 24, 2009 08:46 PM
Originally Posted by ruski (Post 252965)
I like the stitched leather panels inside, would be nice to retrofit them to my 2008.
I like it too! Will change it once they got the replacement part available for the 2010 Outlander GT, as the upper glove box was damaged by air freshener anyway.
armymen Nov 28, 2009 09:08 PM
Well is that possible to make that NEUTRAL thing to save gaz true the computer ?
And what is the mod they did to the engine for that Extra 10 HP ?
its the same engine, so it probably probable to make it perform the same way.
personnaly i dont realy like the new nose of the outlander, but will like to have the small new upgrade :)
Dr. Zoidberg Dec 3, 2009 08:12 PM
Re: +10hp I believe they retuned the engine but as 91 octane is recommended you probably will need the high test to truly get the 10hp gain and at > $0.10/litre over regular it more than offsets the cost savings that the neutral tranny gives you.
I was thinking about mimicing the s-awc on a older outlander. While the likelihood of getting the exact same system/performance is low, I wonder if installing a mech limited slip up front and a helical limited slip at the back would give something similar? Anyone know if LSDs would be compatible with the older outties awc and asc systems?
Dr. Zoidberg Dec 5, 2009 07:16 PM
Originally Posted by DEOUTLANDER (Post 253589)
Hey man you kno ur ish can you turbo charge my outlander or super charge it?
You could do both. The 'Evolander' was/is supercharged.
http://www.topspeed.com/cars/mitsubi...r-ar15250.html
You have the potential for more power with turbo, but the down side is usually some sort of turbo lag. For sure will need 91 octane for either option.
I wonder if anyone has installed an aftermarket limited slip?
ark_royal Dec 11, 2009 04:24 AM
I am finding some mods too. Now Cusco has coilover kit for 2007-up Outlander. It can be used on both CW5W and CW6W.
tcp Dec 11, 2009 09:17 AM
Compression
The 2010 outlander has a higher compression ratio. 10.2 instead of 9.5 or something like that. That points to mechanical differences.
ruski Dec 11, 2009 01:33 PM
You got the air freshener damage? me too. :(
