-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Dia Queen ATF substitute? (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/dia-queen-atf-substitute-40613/)
GREG Sep 18, 2011 01:37 PM
My 07 Outlander is coming due for a transmission fluid change. I was surfing the net for Dia Queen and came across ENEOS Transmission Fluid ATF
If you click on the attached link you will see charistics and properties. It says that it is a direct replacement for the Dia Queen. It is also a lot easier on your wallet. I know that there may be other substitutes that may be safe to use but I am curious if this may be safe to use on my outlander. If I have to pay top dollar for Dia Queen......so be it. Its a lot cheaper then replacing my transmission.
Nippon Oil | ENEOS ECO-ATF
MitsubishiDiaQueen ATF SP-II...Yes
DiaQueen ATF SP-III........Yes
DiaQueen ATF II.............Yes
DiaQueen ATF AW...........Yes
DiaQueen CVT Fluid J1......NO
DiaQueen ATF SK............Yes
ccernst Sep 18, 2011 08:04 PM
DiaQueen is a brand and the site did not specify ATF-J1/J2/J3....so I'd say it is not compatible. Might be worthwhile to inquire though.
benshepherd Sep 20, 2011 06:25 PM
At $9 per quart it isn't that much cheaper - I think I paid approx $11 from my mitsubishi dealer for Dia Queen. I guess it depends what your dealer is charging and locality.
GREG Sep 21, 2011 05:54 PM
That not too bad I haven't looked in to the price from the dealer. I thought the dealer price was around $25 US. That is why i was looking into a alternative fluid.
Thanks ben. I will do more research.
