-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Diagnostic Software (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/diagnostic-software-35989/)
Edmoutlander May 26, 2010 02:27 PM
Diagnostic Software
Hi,
I am new to the Mitsu "Family" - Just got a brand new 2010 Outlander LS ( Canadian model) 3.0L
Before this I had a Vw Passat 2008
I have to ask you guys if anyone know what "diagnostic / communication software " do you use for this car.
I know that if the car is equipped with the MMCS - you can do some adjustments ,.... like reprogramming the door locks and so on " but without the MMCS you need a software and a laptop... Any advice?
PS: On Vw there was a software used for the above purposes and also for scanning CEL and so on
Many thanks guys
ccernst May 26, 2010 11:09 PM
you can use obdII/CAN scanners to pull codes and read data. I've got a Acctron 9180 and can read many data feeds. As for Tunning, I dunno about that.
Edmoutlander May 27, 2010 09:33 AM
Thanks Ccernst,
Ya... I was looking more for a similar software with the one from VW ( VAG - COM from Ross tech) as you pcan do some "tuning" without having the MMCS....
I hope someone here in this forum know something about this....
tcp May 27, 2010 10:08 AM
not really available
The WAG equivalent is dealer specific and very costly, if they'll even sell it to you. It's call MUT (MUT III for the latest version).
https://www.mitsubi****echinfo.com/epacarb/default.jsp
bitDawg May 27, 2010 10:08 AM
The Tactrix 2 connector and free software is the closest you'll get. I haven't used it yet, but I plan to. My Outlander is supposed to arrive in July. I have also used VAG-COM for my Jetta TDI.
The software was designed for tuning the lancer, but it supports anything there is a definition for.
Edmoutlander May 27, 2010 10:18 AM
Thank you so much bitDawg,
Any idea what is the software name and from were I can download it?
bitDawg May 27, 2010 12:58 PM
It's called ECU Flash... available from Tactrix's website along with the connector and adapter (both are required to actually flash the ECU, but only the connector is required to read CEL).
http://tactrix.com/
mda185 May 31, 2010 03:45 PM
http://tactrix.com/
Is the Tactrix connector required to read CEL data or can any generic OBD II connector be used? I looked on their web site but this information is not there. Their FAQ page does not have a lot of info yet.
bitDawg Jun 1, 2010 10:11 AM
Any ODBII scanner can read the error codes... the Tactrix connector without the patch adapater functions like an ODBII scanner (assuming you have a laptop and software installed... just like VAG-COM).
mda185 Jun 2, 2010 09:48 AM
I should have been more specific with my question. Any OBD II scanner can read the generic CEL codes and sensor data that all car manufacturers must use as a minimum set of data. All car manufacturers have additional sensor data defined that is proprietary to them and can only be read by specialized software and/or hardware. ECU Flash must be able to read the proprietary Mitsubishi parameters for it to do its job. I am just wondering if ECU Flash will only do this if paired with the Tactrix OBD II adapter.
I own software from AutoEnginuity that can read CELS and all generic OBD II data. It is also capable of reading all of the proprietary Mitsubishi data if I shell out another $230 for what they call the Enhanced Mitsubishi package. I am not going to do this if ECU Flash will do the same thing with my present OBD II adapter. If I have to buy the Tractrix adapter, the cost difference starts to shrink.
