Diaqueen ATF-J2 Aftermarket Fluid
Old May 1, 2013 | 09:07 AM
nesser's Avatar
Default Diaqueen ATF-J2 Aftermarket Fluid
AMSOIL just recently upgraded the specifications on their ATF fluids.
You will find that the Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL) in the blue bottle now sports the Mitsubishi ATF-J2 specification.
I give more detail about the update here:
http://amsoil.nesser.org/2013/04/ams...pecifications/
The application guide on AMSOIL's website hasn't been updated yet but the transmission product specifications have been.
FYI: AMSOIL does not currently have an ATF for CVT transmissions.
I'm excited for a new aftermarket fluid option. I've got a 2L of DiaQueen J2 from the dealership to use up and then I'll be using ATL going forward.
Old May 1, 2013 | 11:57 AM
ccernst's Avatar
very interesting, I'll be watching this a bit closer. I'm coming up on another change I think this summer...I need to check my records.
Old May 1, 2013 | 02:17 PM
**** YES!!! Perfect.
Old Jun 13, 2013 | 07:59 PM
Outlaander's Avatar
Now all I need is an $11.50/L Amsoil substitute for ATF-J3.
Old Jun 17, 2013 | 08:55 AM
nesser's Avatar
Doesn't exist yet but I'd suggest contacting AMSOIL technical services to ask for it. The Tech Services people are really helpful, will take a few days to reply though.
They track those requests for future fluid considerations. The more people that ask for a specification the more likely it will be researched and tested.
AMSOIL Product Technical Services Department
Old Jun 17, 2013 | 12:26 PM
Outlaander's Avatar
Done! I hope others needing a less-expensive substitute for J3 do the same.
Old Jun 19, 2013 | 10:33 AM
Outlaander's Avatar
Got a reply from Amsoil today.
"At this time, AMSOIL does not offer an ATF fluid meeting Diaqueen ATF-J3 specifications. Depending on the physical and frictional characteristics differ from our current automatic transmission fluids we offer, we may offer something in the future. If this fluid specification is a completely different oil than any previous transmission fluids offered by Mitsubishi, it may require a completely different formulation, and may not be available."
Not very hopeful, I'd say.
Old Jun 19, 2013 | 03:22 PM
OutlanderGT's Avatar
So the J2 is what the outlander V6 (6AT) uses right?
I don't understand why these transmission requires diaqueen fluids, I thought similar transmission are used in toyota and nissans
What is the price for the Amsoil ATL (qt)?
Old Jun 19, 2013 | 08:50 PM
ruski's Avatar
OK, how many quarts do we need to just drain and refill?
Old Jun 19, 2013 | 11:38 PM
Outlaander's Avatar
I have a 2010 XLS. The maintenance manual calls for DiaQueen ATF-J3. I believe the previous years of V6 call for ATF-J2.
You'd have to ask Mitsubishi exactly why they use DiaQueen fluids. Don't hold your breath waiting for an answer.
