Doing it: HID Retrofit ADDING PROJECTORS to Refelctor Housings
K, I've decided I've had it with my Stock Halogens...but I will not put An Hid Kit into a reflector Housing. So its time for a retrofit with Prjector Lenses....
So I have been speaking to Matt at The Retrofit Source, and I'm about to take on the Bi-Xenon (maybe just the Low Beam kit if the Bi-Xenon is too complicated) adding projector housings to my stock reflectors.
Heres the kit.
Bi-xenon FX-R Stage III Kit: http://www.theretrofitsource.com/pro...roducts_id=141
FX-R Bi-xenon Projectors (LHD)
Morimoto 3Five Ballasts
Morimoto 3Five D2S Bulbs
9006 relay wire harness + high beam taps
Appollo Shrouds
Not going to add Angel Eyes (too fake looking)
So basically this is an HID kit wiht Ballast and everything but you need to add the Projector housigninto the headlight assembly. Not too much fabricating, apparently done with a Dremel and some glue.
Also this wont effect DRL's as they are run on a sep bulb outside of the Projector (clearing this up with Matt to make sure).
more info to follow tomorrow...
Heres the kit.
Appollo Shrouds
airedale1974
02-24-2010 07:58 AM
