DPF system service required msg
Old 08-11-2018, 04:31 AM
Hench's Avatar
Default DPF system service required msg
Hello all
I have a 2013 2.2 diesel. Recently the "DPF system service required" mesaage has came on.
From what understand this is due to excessive oil so had the oil and filter changed. However the message is still on, does anyone know if this can only be reset by the dealer?
would disconnecting the battery potentially resolve this?
thanks in advance.
Old 08-14-2018, 03:59 PM
binzd's Avatar
have you been for a good freeway run yet?
Old 08-21-2023, 07:30 PM
JVD076's Avatar
Had a similar issue dashboard alert read acc service required and check DPF system. Pajero does not pick up power. Issue was busted/tear in engine hose hence the vehicle was loosing pressure and not able to accelerate. This was the cause in this scenario.
Ulcerrator
04-05-2022 12:12 AM
Shmelvis
01-13-2020 04:23 PM
msag001
01-14-2017 09:59 AM
dexter00023
Other Mitsubishi Models
10-13-2014 01:44 PM
Buckmaster
07-27-2012 12:01 AM
Quick Reply: DPF system service required msg
